JD 301-A Hydraulic Pump?
Omac
What is the part connected directly to the hydraulic pump at the front? After cleaning the tractor, the small leak doesn't appear to be in the hydraulic pump. It is coming out directly ahead of the pump toward the transmission. Very small leak so I don't think I'm going to mess with it. I wish the blow-out diagrams in the parts manual showed where the parts were located on the tractor.
Do you have the little German pump or USA pump? If USA, there might be a plastic drain line that runs from the pump to the transmission case.
