JD 3010 Carb adjustment
Anonymous-0
I replaced the alum carb on my 3010 with a new cast iron one . How do I adjust[ set ]the needle valve etc ? It tries to start now but won't keep running thanks for any info. TOM
Adjust the screw on top at slow idle where the engine runs the best. Set the bottom screw at 1 1/2-2 turns open. Then with the engine warmed up real good and the throttle set wide open,very slowly turn the screw in until the engine starts to lose RPMs. Then slowly open the screw until the engine runs rich. Usually about 1 1/2 open . Then split the difference.----Then repeat the process to fine tune it.Slow idle speed should be set at 600 RPM.
