JD 3010 Hydraulic Pumpl Replacement
vinnivee
This message is a reply to an archived post by j hikemper on February 12, 2011 at 04:53:27.
The original subject was "Re: JD 3010 Hydraulic Pumpl Replacement".
I have a JD 3010 Diesel and the hydraulics dont work at all.....where do I start? Filters or screens?
Vince
509 480 8412
FIRST thing is to make sure the front/main pump is actually turning.
Sometimes the splines strip in the coupling that clamps to the pump shaft.
At this point, having a FACTORY shop manual with it's detailed troubleshooting instructions is a great help.
Short version, check for transmission oil pump flow (flows forward to the oil cooler, and feeds the main pump.
If good flow, problem is in main pump.
If little or no oil flow from transmission pump, could be a clogged suction screen, or a failed pump. Believe pumps occasionally get whacked when the differential fails and the pin comes out and whacks the pump.
