liamtrac01
I just bought a JD 301A I am looking to buy a loader. There is a JD 47 for sale in my area for 1000$ the seller says it came of a 2020. Would this loader work? Is it worth buying then trying to track down the right brackets?
The 301A is a 3-cylinder, like the 1020, the 2020 is 4-cylinder. The parts catalog for the 1020 (3 cylinder) uses different rear brackets than the 2020. Wouldn't he need the brackets for a 1020 to install on his 301A. It looks like they move the loader connection rearward a bit. It is likely the 1020 rear brackets could be reworked to make the offset.Price sounds cheap enough & yes it will fit a 301A. Model 47 is lighter duty than some other JD FEL models. Mounting brackets for 2020 will fit 301A but will require being shorter in length
Ok still digesting all this. I very new to this. What I’m understanding is that this would be a lot of work and it might be best to wait and find a 145/148? That fit without any work?We have 47 loader on our 2020 and we have 301A with what appears to be a 148 loader on it. Comparing the 148/145 mounting of the 301A to the same loaders on the 2030s here, the 301A uses shorter mounts. The 47 mast has braces welded to it that attach to front mounts. not a non-braced mast like the 148/145 loaders have. This is why I think the front brace mounts for the 47 will go in the same location as they are on the 2020 and the mast pockets for a 1020 are offset to the rear to fit the mast, with the braces, as the flywheel housing bolts are the connection point for both rear mounts. The mast braces would require major rework to shorten the them if the rear mounts are not moved to the rear, if I am seeing this correctly.
I also believe the side frames (between the tractor front support and flywheel housing will be needed for the 301A. I may have missed them but I only found a right hand side frame called out for a side mount mower, in the 301A catalog. That right hand frame has the same part number as the 1020 RH frame. I believe the one for the left side 1020 will fit the 301A as well and both will be needed before the loader mounts are installed, to lessen the chance of the loader breaking the tractor in two.
Here is link.to the 47 parts catalog so liamtrac01 can compare the 1020 and 2020 mounting components for the 47 loader, piece for piece to find the ones that have different part numbers.
47 Loader parts catalog
Also is there any difference in the 1020 and the 301a?Ok still digesting all this. I very new to this. What I’m understanding is that this would be a lot of work and it might be best to wait and find a 145/148? That fit without any work?
I think you mean 146, not a 148.We have 47 loader on our 2020 and we have 301A with what appears to be a 148 loader on it. Comparing the 148/145 mounting of the 301A to the same loaders on the 2030s here, the 301A uses shorter mounts. The 47 mast has braces welded to it that attach to front mounts. not a non-braced mast like the 148/145 loaders have. This is why I think the front brace mounts for the 47 will go in the same location as they are on the 2020 and the mast pockets for a 1020 are offset to the rear to fit the mast, with the braces, as the flywheel housing bolts are the connection point for both rear mounts. The mast braces would require major rework to shorten the them if the rear mounts are not moved to the rear, if I am seeing this correctly.
I think you mean 146, not 148.We have 47 loader on our 2020 and we have 301A with what appears to be a 148 loader on it. Comparing the 148/145 mounting of the 301A to the same loaders on the 2030s here, the 301A uses shorter mounts. The 47 mast has braces welded to it that attach to front mounts. not a non-braced mast like the 148/145 loaders have. This is why I think the front brace mounts for the 47 will go in the same location as they are on the 2020 and the mast pockets for a 1020 are offset to the rear to fit the mast, with the braces, as the flywheel housing bolts are the connection point for both rear mounts. The mast braces would require major rework to shorten the them if the rear mounts are not moved to the rear, if I am seeing this correctly.
Basically there's not a lot of differences between a 1020 & 301A except color of the paint. 301A & 1020 shared same part # for frt hyd pumps. 1020 were built '65-'73 while 301A were built '74-'85. 301A could have a heavier non-adjustable front axle than a 1020 & that HD axle wasn't offered on a 1020.Also is there any difference in the 1020 and the 301a?
145, 146, and 148 all will mount with the same tractor mounts on the tractors I mentioned, I have all three loader models.I think you mean 146, not 148.![]()
I agree with Tx Jim, there is little difference between a 301A and 1020.Ok still digesting all this. I very new to this. What I’m understanding is that this would be a lot of work and it might be best to wait and find a 145/148? That fit without any work?
