JD 3020 front panel decal placement
I painted the front side panels on my JD 3020 Diesel and woud like to put decals in the right locations, guess I should have measured it out before sanding them off, took a picture with digital camera and wife deleted by accident, this is with a cab on tractor so it is the side panels up by the fuel tank. Thanks, Terry
If someone tells me I'm wrong I won't argue. As far as I know from the factory all of them had the decals on the rear engine shields. The only time they are on the front is if the rear shields are gone or an aftermarket cab is put on later. So my guess would be put them where ever you want because thats just were someone else put them before you anyway.
Kansas 4010
IIRC JD new generation tractors that came from factory with Stolper cabs had number designations on frt panel covering fuel tank. The numbers were centered about mid-way from top to bottom.
