Hello! Back to the site again, hoping you fine folks can lend your brains.
While running my '81 JD310A backhoe the other day the controls suddenly became jerky (cavitation?), then the right-side stabilizer (passenger side in a car) suddenly extended down to the bottom of the cycle. Tried other controls, and loader suddenly raised up to max height. When trying to lower the loader, the valve wouldn't depress but it felt normal when trying to raise it. Same on the stabilizer, they felt like they were bottomed out. I shut the machine down to check for any leaks or obvious problems, none.
Next day I switched the two hoses on the stabilizer so it would lift up so I could move the machine to my garage. The loader moved up again to max height on its own, the stabilizer moved all the way up. Moved the machine with no issues with steering or drive, though I was in 2nd low gear and only 1000 RPMs, basically idled my way home. The engine is not laboring to lift the loader or stabilizer, when they got to the end of their cycle the RPMs returned to normal. Usually when the backhoe is sitting overnight or a couple days with the stabilizers up, they'll drop to the ground. I don't normally park that way of course. It took a week for the stabilizer to fall to the ground, definitely not how it normally operates. It took several days for the loader bucket to come down as well.
After the pressure was off the loader bucket for a couple days, I tried raising the bucket while the machine was off. Still stuck, so I tried to lower the bucket and the valve felt normal in that direction. The I tried raising it again and the valve worked and felt normal. Did not have the same result with the stabilizer, no movement of the valve when pushing away from me as if I'm lowering it. Used a jack to raise the stabilizer a bit to relieve pressure thinking that would loosen the valve but it had no effect and is still stuck today. All these tests were done on a cold machine that was off. Firing it up caused the loader and stabilizer to lift again.
Easy tests first. I drained the oil and replaced the two hydraulic filters, the oil and filters look fine. Also pulled the sump screen and it was clean. Found some pieces of metal in the hydraulic filter bowl (not the transmission one), they look like pieces of a washer or something, doesn't appear to be spring steel. They're about 1/16" in diameter, ~2mm, a bit flattened, not a completely round cross-section. They're quite chewed up and may have been moving through the hydraulic system a while as none of the pieces are sharp.
Opened the relief valve and found that the "plug", part #AT26171, had the shaft snapped off and the valve was loose. Ordering a new plug, spring, valve and o-ring so that should fix the relief valve, assuming it was broken by the pieces of metal. I have not yet refilled the oil since I need to repair this valve first.
And now for the questions.
Does the stabilizer/loader issue sound like a result of the failed relief valve? I don't know what the symptoms of a failed relief valve would be.
Any idea what those metal pieces are?
Thanks for any help you can offer. I have the service manual, owners manual and parts catalog for this machine but no hydraulic testing tools. Lots of big wrenches and sockets.
