JD 318 coil
1 Dollar
What would a coil that is going bad behave like? Mine starts and runs but is rough, and wont run very well much above an idle once it warms up a bit.
Thanks (1985 JD 318 with points etc.)
I had the coil go bad in mine a few years ago. It would start and run OK until the coil got warm from running and then it would loose power and eventually die. Yours could be the coil - your symptoms sound a bit different from mine.
