I have an JD 318 riding lawn mower. The engin is an Onen. One of the cylinders does not have compression. It was runnig fine before that.
I talked to a small engine house. There the guy said it could be a stulked valve. Is that what it is or is it s combination of both? What do I need to do and were do i can i buy parts of it.
Any help will be greatly appreciated.
First thing to do is get mod number of eng off id plate,then goto ebay & type onan manual in search and buy a service/repair manual for series eng you have & study repair/troubleshooting charts as to 1 or more possible causes of your problem,then start going over eng to locate problem,it probably is a stuck valve/blown head gasket causeing problem,in either case you'll have to remove sheetmetal covers on eng & pull head on cyl with no compression,just to confirm head gasket not blown & valve(s)not stuck open,for parts check yellow pages for a cummins dealer as they now own onan,or take mod spec/type #'s to local mower shop & see if they can lookup & order gaskets/parts needed.
the 318's has either B43G ot the later ones had a P218. IF there's no compression, either the valve is stuck, valve seat is loose or rod broke. Pull the head off and you should be bale to tell
Brad
Before yo spend any money. Take the head off and check the valves. May be a stuck valve or seat loose. Could also just be some carbon that has broken off holding the valve open. I have worked with Onan since 1980,now a retired Onan tech. Have the manuals and will be glad to help you.
How do I know if the seats loose and how do I fix it? The valve I know that I need to take those out and clean with some emery cloth. Once I figure what is wrong with it what is the sequence to tighten the bolts down on the head?
I appreciate all the help that you have given me. Thanks again Brad
If the seat is loose you will be able to see it. Takes a machine shop to replace one. Need to know what engine you have to give you the head bolt readings.
The engine # is B43-GA018/4174C. I took off the head the valves move freely. The valves have some carbon build up. Is that normal and should I clean this up while I have it this fare. The cylinder is not moving. I can push it all the way back if I hold it in and turn the engine over the cylinder will kick back to me. What do I need to do now? Take the oil pan off and go from their?
Thanks again for all of your help. Brad
The cylinder should not move, Pistons move. sounds like you have a broken rod or piston or both $$$$.
Bryce
Sorry for the delay. If the piston will not move then yes you have a broken rod. You will need to remove the oil pan to check it out.
I took the head off and the oil pane off. I have the parts on order. The only thing that I need now is in what order do I need to tighten the head bolts down and how tight? Also how tight and what order do I need to tighten the oil pan down to.
Thanks for all your help again.
brad
