(quoted from post at 23:10:02 03/02/11) The second number is the capacity of the baler. 2 being lowest, 3 in the middle and 4 being highest capacity. David
(quoted from post at 22:46:00 03/02/11)
I know of 336 and 338 balers, but can anyone give me any info on a 328 baler? I was wondering if it makes a normal sized bale, quote]
328 has same width pickup attachment as 338 but 328 only has 4 bars with teeth(52 teeth) while 338 has 6 bars(78 teeth). Both have same weight flywheel. Balecase was the same on both models. I also think 328 only came in twine version only no wire.
(quoted from post at 09:50:31 03/03/11) The knotters are quite similar, but the 328 knotter has some improvements for servicing. We have broken the left side axle stub shafts on both of them.Paul in MN
(quoted from post at 14:36:36 03/03/11) Jim,I have rebuilt the knotters on both of these balers, and it is getting a little fuzzy in my mind what the differences are. I think there was some difference in the wiper arms, making that adjustment easier in the 328.
Maybe the bearing you describe is located near the middle of the auger.Paul in MN
