jd 350-b starter removal ?
Bruce L
hi the new batteries didn't do the trick on my jd 350-b dozer think I need to pull the starter; how do I do this looks like I need to take fuel pump off ,oil dip stick out, maybe fuel filter and oil filter also. how many bolts are there I see 2 right now one at 12 o'clock and one at 6 o'clock if there one at 3 o'clock lord help me looks like I will not be able to use a socket and extension . any help would be great to get this done. I once saw a special jd starter wrench on ebay now thinking I should have bid higher on it. I live in ct if anyone around that I could hire ?
Its a b!tCh of a job but doable. Nothing really complicated but time & patience is required. Biggest help would be a starter-alternator wrench 1/2 " one end, 9/16ths on other end. NAPA or any auto store will have it. It is shaped like the letter "C" with a box end. I have used a torch & grinder to make a wrench but buying one is best. Parts book will answer your questions or a parts diagram online you can print out.
