Jd 3950 chopper hyd valve
mhudgins
I purchased a jd 3950 and it was pulled by a 1135 massey and I am using a jd 7330 and I looked in the manual about changing from a open system to a closed system and I do not have the red screw the manual talks about using and wondered what I needed to do
Go back to jd or if someone had done something else to change the system
If they ran it on an open center system then you will need to remove the BLUE screw and put in the red screw for the closed center system. The screw not being used is usually in the storage position. in the top of a dummy valve next to the valve you need to change. If there is no red screw and just the blue then you will need to get a red screw and replace the blue with it.
