Jd 40 T pto question
PPOP
My 40t JD pto will engage to correct rpm speed but when I pull lever back to disengage it still turns at a real low rpm. Any ideas.
(quoted from post at 09:46:22 06/24/23) Do you think it will stop whe I hook up to a bush hog
As you likely already know, you need to use an overrunning coupler when operating the rotary cutter so it's inertia doesn't propel you into trouble when you step on the clutch and need to stop quickly.
