Jd 400 wheel loader backhoe
Does anybody have this hydraulic pressure control valve assembly? Thanks for now
Cracked housing from impact with a stump,was hoping it was just the hose and fitting.
I have a 410 backhoe. That looks very similar to the one on mine. You might check with JD to see how many models will interchange with it.
Wengers equipment in Myerstown, PA has a used parts department for both construction and agricultural equipment where they buy machines and part it out. They might have one. I'm sure they would ship if they do.
It looks like your 400 has the valve for the 50 CME pump with power steering and equipped with hydraulic drive mower, from the parts catalog description. R39323 is the housing part number, and it subs to T120368. Those numbers should help you in your search. I didn't find a part number for the complete valve, but it appears some use those numbers for advertising the used valves. You could call PartsASAP and see what they have. eBay has a used one listed.
On the same industrial 400 would you get hydraulic cylinder reseal parts from the dealer or source them from a hydraulic shop?
