My father-in-law purchased a 4010 last year from a friend's estate and handed it over to me for keeping up. Apparently, this tractor always needed a shot of ether to start when cold, but always fired right up after warming up. This spring, it would start and then die out after 15-30 seconds regardless of what I did. I learned to check the injector pump for black plastic flecks and that's what I found. I decided that I'd give rebuilding the injector pump a try and ordered the manual, rebuild kit, and the new fused governor cage rather than replacing the plastic grommet. I have pulled the pump apart a number of times to ensure that I have everything assembled correctly but I now am not sure that I have the engine on Compression TDC.
First Question: Is there a way to determine TDC on compression stroke without taking the valve cover off?
Compounding Issues: It is terrible trying to get this tractor to crank! I have pulled and cleaned the starter, replaced the starter solenoid and the relay. I brought the starter in to a great shop and they found no issues with it. I have replaced all of the cables to the battery and have excellent ground as well as a new battery (This had a single 12v battery so I replaced it with the highest Amperage battery Tractor Supply carried.) I feel that I'm fighting two different issues at the same time, but does anyone have suggestions that might help?
This is the first time I've messed with a diesel, but I've done a lot with gassers.
