Wondering what the significance is of this idler gear/shaft on the output of transmission planetary.
Brought home a 1966 model, drained hydraulic oil and a couple bearing balls fell out. Found the ball bearing on front of idler shaft is the source and the idler gear has a couple teeth damaged on rear of gear. Going to be a yard tractor for running grain auger and moving pallets around with loader. Have a 4020 SR since new so it will keep doing the other jobs outside of yard. I can always split this PS unit next winter, but would like to run it a season and see if there are any other issues like maybe PTO slipping under load before considering splitting. Yes, I see it would be a double split so rather not do it right now.
