jd 4020 w possesed loader...???
glennster
neighbor has a jd 4020 with a woods 340 loader. runs off the rear left remotes. on the console the far left outer control works the bucket tilt, next one raises and lowers the loader. when tilting the bucket either up or down, centering the control, then the bucket will cycle either down or up, and then stop near its intended position. almost like a draft control is kicking in. it will also do this occasionally on the up down for the loader. any idea what is causing this?? real annoying.
glennster[/quote]
Is loader operated only from SCV's or is an ind spool valve plugged into LH SCV?
If SCV only operated I agree that SCV's need repair/adjusting.
If ind valve spool or lands in ind valve are worn.
