Been doing some fine tuning on my pressures for my JD 410 backhoe. Main pump is new and has about 200 hrs on it. Trans pump is unknown age but last time I checked it was pumping well over 4 gpm. I got the standby pressure up to 2500 psi when cold. Pressure relief valve was a mess. Seems like parts where missing in the washer / shim area. Nevertheless I machined a new piece / cleaned it all out and it now cuts in at 1700-1800psi when cold.
When cold and running at the pressures above, the machine is unbelievable in power. Almost like new, and no leaks. Work it hard for a while and the pressure drops. 30 minutes of hard use and the standby pressure is at 1500psi and of course the pressure relief is using all of that 1500psi.
Filters where just replaced, trans pump screen cleaned and I have a newer main pump with no screen in it. I did have water in the system at one point, and only completely drained it once. Since then about 15 gals have been added thanks to filters changes/ blown hose / etc. I also just completely cleaned out the oil cooler fins.
I will admit to using the cheapest hydro oil and I am sure some will jump on me for that but I cannot imagine that a "better" oil will make a huge difference. No foaming in the oil and it does look clean.
I am at a loss as to why the pressure is dropping when warm and would to welcome to any thoughts on the matter. ?????????
On a plus note, I almost have the machine "dope free" when cold. Lucas fuel additive and a new thermostat along with the good advice from a few in here have helped me. I assume this points to a dirty injector somewhere.
