JD 42 combine
schrade
Does any one know where to get a new double sided belt for a 42 combine Have tried Deere not available don"t know part # or size off hand
I beleive the "40" combine is the self propelled version. Most of the parts are interchangable. You might talk to a junk combine dealer! Some of them are a treasure of information; even when they cant sell you anything!
Scotty
Jaydee Enterprises or JD Hotline. JD dealers have connections with other dealers nation wide that stock NOS parts. If you beg hard enough they may comply. Good Luck!!
Schrade, if you log onto the Deere parts site you can then look up the part number of this belt. After you do that you will see a notation that says "part specifications" or something like that. It will give the length and size of the belt you need, assuming it is still available in the Deere system. Hope this helps. Mike
Here are are a few pictures from the owners manual!
Scotty
Thanks for the pictures, the largest pull behind I've seen in this area is a model 30. I had a model 40 self propelled here for awhile that I bought for junk price for the engine.
Both NAPA and my local Deere dealer can cross reference my part numbers including belts. Napa has had every one for my JD 30 combine included double sided.
Deere made all manuals available online here,
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
I"ve just downloaded the manual, and called Deere with the numbers and either they or Napa cross them and Napa gets them for me in a day.
Good luck.
Ron
