JD 4230/4430 axles
4010 puller
Hey Guys:
I"m looking for a set of factory wedgelock/9 bolt dual hubs for a 4230. Are a 4230 and 4430 the same sized axle? I"m pretty sure they are (both 3 3/8"). I saw a set of 4430 hubs listed for sale as 3 5/8", which is which?
PLANETARY AND REAR AXLE
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 R53658 SNAP RING 2 (A)
R53659 SNAP RING 2 (B)
2 R53641 SHAFT 2 - 040770 (A) 860MM (33-7/8") AXLE, 2286MM (90") TREAD, (SUB R60077)
R60077 SHAFT 2 040771 - (A) 857MM (33-3/4") AXLE, 2286MM (90") TREAD
R53643 SHAFT 2 - 040770 941MM (37-1/16") AXLE, 2438MM (96") TREAD, (SUB R60076)
R60076 SHAFT 2 040771 - (A) 938MM (36-29/32") AXLE, 2438MM (96") TREAD
R53642 SHAFT 2 - 040770 (A) 1043MM (41-1/16") AXLE, 2642MM (104") TREAD, (SUB R59935)
R59935 SHAFT 2 040771 - 067998 (A) 1039MM (40-29/32" AXLE, 2642MM (104") TREAD
R64521 SHAFT 2 067999 - (B) 1039MM (40-29/32") AXLE, 2642MM (104") TREAD
R53644 SHAFT 2 - 040770 (A) 1159MM (45-5/8") AXLE, 2870MM (113") TREAD (SPECIAL DUAL) (SUB R60078)
R60078 SHAFT 2 040771 - 067998 (A) 1156MM (45-1/2") AXLE, 2870MM (113") TREAD (SPECIAL DUAL)
R64522 SHAFT 2 067999 - (B) 1156MM (45-1/2") (SPECIAL DUAL)
3 R65648 SPACER 2 (A) 15MM (.59") THICK, (SUB FOR R61175 OR R63105)
R63106 SPACER 2 (B) 13MM (.50") THICK
4 R33026 SEAL 2 (A)
RE33499 SEAL 2 (B) (SUB FOR AR68721 OR AH93852)
5 R57269 OIL CUP 2 (A) (SUB FOR R18128)
R59074 OIL CUP 2 (B)
6 JD8191 BEARING CONE 2 (A)
JD10002 BEARING CONE 2 (A) (UNDERSIZE)
JD8962 BEARING CONE 2 (B)
JD10003 BEARING CONE 2 (B) (UNDERSIZE)
7 JD8214 BEARING CUP 2 (A)
JD8248 BEARING CUP 2 (B)
8 15H559 PIPE PLUG 2 1/4"
9 19H1863 CAP SCREW 24 5/8" X 3"
10 R76845 PINION 2 (USE WITH AR105556)
R56733 GEAR 2 021270 - (SUB FOR R61176 OR RE13477)
11 AR34755 HOUSING 2 - 021269 (A) (D) (E) (MARKED R34940, R64791 OR R76843) (SUB AR105556)
AR67668 HOUSING 2 021270 - 040770 (A) (C) (D) (MARKED R34940) (SUB AR81426)
AR81426 HOUSING 2 040771 - (A) (D) (MARKED R64791)
AR54736 HOUSING 2 - 021269 (A) (C) (E) (MARKED R50160 OR R64791) (SUB AR105556)
AR67669 HOUSING 2 021270 - 067846 (A) (C) (MARKED R50160) (SUB AR81426)
AR81426 HOUSING 2 067847 - (A) (C) (MARKED R64791)
AR80665 HOUSING 2 067999 - (B) (MARKED R64520) (SUB RE192708 USED PART)
RE171036 HOUSING 2 (SUB FOR AR105556) (USED PART)
12 R34848 GASKET 2
13 R33027 SEAL 2
14 JD8213 BEARING CUP 2
15 JD8177 BEARING CONE 2
16 R65543 DOWEL PIN 6 (SUB FOR R33024)
17 R33022 THRUST WASHER 12
18 R33028 NEEDLE ROLLER 198
R61033 NEEDLE ROLLER 144 (USE WITH R59929 OR R108996)
19 R33004 PINION 6 - 021269 (E)
R56732 PINION 6 021270 - 040770 (E)
R59929 PINION 6 040771 - 51 MM (2") (SUB R108996)
20 R97998 SHAFT 6 040771 - (USE WITH R59929 OR R108996) (SUB FOR R59930)
21 R63112 PINION SHAFT 6 - 040770 (E) (SUB FOR R33021)
22 R42101 SHIM 2
23 R33029 SNAP RING 2
24 R42901 PLANET PINION CARRIER 2 - 040770 (E)
25 R59933 PLANET PINION CARRIER 2 040771 - (USE WITH R59929 OR R108996)
26 R48460 WASHER 2 - 040770 (SUB R72169, THIS APPLICATION)
R72169 SPACER 2 040771 - (USE WITH 51 MM (2") FINAL DRIVE AND R59929 OR R108996) (SUB FOR R33023)
27 R82175 CAP SCREW 2 HS, SAE 8, (SUB FOR R26011 OR R60032)
28 R26012 LOCK PLATE 2
29 R45779 SHAFT 2 - 021269 (E)
R67198 SHAFT 2 021270 - 040770 (E) (SUB FOR R56731)
R59928 SHAFT 2 040771 - 063071 51 MM (2") (SUB R62685 AND R85029)
R62685 SHAFT 2 063072 - 51 MM (2") (USE WITH R62686, R59929 OR R108996)
30 R59439 SHIM AR .13 MM (.005")
R59440 SHIM AR .51 MM (.020")
R61461 SHIM AR .08 MM (.003")
31 F2380R WASHER 1
.. RE13476 KIT 1 51 MM (2") WIDE FINAL DRIVE (BOTH AXLES) (SUB FOR AR80300) (SUB RE41241)
.. R72232 BALL AR AXLE SHIMMING KIT, (SUB FOR AR94976)
(A) 86 MM (3.4") AXLE
(B) 92 MM (3.6") AXLE
(C) ROLL-GARD OR SOUND-GARD BODY
(D) LESS ROLL-GARD OR SOUND-GARD BODY
(E) IF AR80300 OR RE13476 HAVE BEEN INSTALLED, ORDER AR81426
5 R65648 SPACER 1 15MM (.59") (SUB FOR R33020, R63105 OR R61175)
6 JD8191 BEARING CONE 1
JD10002 BEARING CONE 1 (UNDERSIZE)
7 JD8214 BEARING CUP 1
8 15H559 PIPE PLUG 1 1/4"
9 19H1863 CAP SCREW 13 5/8" X 3"
10 R76845 PINION 1
R56733 GEAR 1 51MM (2") FINAL DRIVE, (SUB FOR RE13477 OR R61176)
11 AR54736 HOUSING 1 (A) (MARKED R34940, R50160 AND R64791) (SUB FOR AR34755) (SUB AR105556)
RE171036 HOUSING 1 (SUB FOR AR105556) (USED PART)
12 R100637 GASKET 1 (SUB FOR R34848)
13 R33027 SEAL 1
14 JD8213 BEARING CUP 1
15 JD8177 BEARING CONE 1
1 R53658 SNAP RING 1
2 R53641 SHAFT 1 860MM (33-7/8") (ALSO ORDER R53658) (SUB FOR R33015) (SUB R60077) (2311MM (91") TREAD)
R53643 SHAFT 1 941MM (37-1/16") (ALSO ORDER R53658) (SUB FOR R40262) (SUB R60076) (2640MM (104") TREAD)
R53642 SHAFT 1 1043MM (41-1/16") (ALSO ORDER R53658) (SUB FOR R33018) (SUB R59935) (2844MM (112") TREAD)
R53644 SHAFT 1 1158MM (45-5/8") (ALSO ORDER R53658) (SUB FOR R41845) (SUB R60078) (SPECIAL DUAL)
3 R33026 SEAL 1
4 R28128 RETAINER 1 (SUB R57269)
16 R65543 DOWEL PIN 3 (SUB FOR R33024)
17 R33022 THRUST WASHER 6
18 R33028 NEEDLE ROLLER 99
19 R33004 PINION 3
20 R97998 SHAFT 3 (SUB FOR R59930)
21 R63112 PINION SHAFT 3 (SUB FOR R33021)
22 R42101 SHIM 1
23 R33029 SNAP RING 1
24 R42901 PLANET PINION CARRIER 1
25 R59933 PLANET PINION CARRIER 1
26 R72169 SPACER 1 (SUB FOR R33023)
27 R82175 CAP SCREW 1 HS, SAE 8, (SUB FOR R26011 OR R60032)
28 R26012 LOCK PLATE 1
29 R45779 SHAFT 1
.. RE47883 KIT 1 (B) 51MM (2") WIDE FINAL DRIVE, (SUB FOR AR80300, RE13476 OR RE41241)
(A) WHEN AR80300 OR RE13476 HAS BEEN INSTALLED, ORDER AR81426
(B) FURNISH COMPONENTS
I know that a 4020 and 4430 are the same 3/3/8 so I think 4230s work also,the cast factory outsides are the same but wedges are different on some models
(quoted from post at 23:16:15 01/04/11) Hey Guys:
I"m looking for a set of factory wedgelock/9 bolt dual hubs for a 4230. Are a 4230 and 4430 the same sized axle? I"m pretty sure they are (both 3 3/8"). I saw a set of 4430 hubs listed for sale as 3 5/8", which is which?Thanks
According to JDparts.com in PC # 1294 for 4230 &PC # 1295 for 4430 under Dual rear wheels the hubs and wedges are the same for both models if the 4430 has the smaller axles(86 MM).
DUAL REAR WHEELS™BR>(ROW-CROP) (86 MM AXLE)
I have a set of JD 86 MM hubs I pulled off my 4255 that I'd sell for $300 but shipping might be prohibitive. If interested I could contact an over the road trucker I know and possibly line up shipping that way.
I have a set that came off a 4230. They are 3& 3/8ths. The 4430 is probably 3&5/8. However, in the 30 series tractors, sometimes the earlier years will have one size and the later years of the same model (ie 4430), will have a larger size axle. I'd sell the set I have for $225. There is one broken off bolt in one of the hubs. I'm in West Central Illinois.
There are two different axles offered for a 4430,86mm(3.4") and 92mm(3.6") the 92mm were the long axle option.
Jim:
If the 86 mm is the 3 3/8" axle I could be interested. Can you get me a shipping quote? My ZIP is 45750.
My hubs are definitely 86MM(3-3/8") as I sold them to a man thinking they were 92MM for a 4440 and they were too small. I researched better and found out that my 4255 had 86mm axles. My hubs have the wheel mounting bolts and re-enforcement rings for outside of wheels. I'll check on shipping. According to JDparts .com they should weigh in at close to 200#'s for the pair.
Doug if you could check on shipping for me, the price is right. My ZIP is 45750 and i guess you could check with ccx or somewhere. Would ups ship them if you shipped them individually?
Thanks,
John
