JD 4255 MFWD Flashers
Dave Graeve
I have a Jd 4255 MFWD European It has a seperate switch on the dash for the flashers with a triangle on it like a slow moving vehicle sign on it. last fall I switched the implement plug on the back of it. I had it wired wrong and then switched it to the way the grain cart was wired.
I lost the flashers, so I went to the fuse panel to replace the fuse and there were no fuses where the left and right fuses go, but I did find to green wires pluged into the cold side of the fuse panel. So I unpluged the 2 wires and put fuses in where you usually do,then I had amber lights above the cab and in front fenders as long if I had the turn signal lever to left or right turn as this is the light configuration on this tractor. Does any one know what feeds the switch on the dash. Any help much appreciated, I'm Stumpted! Dave
