JD 430 W all- fuel
gmjdtman
I just purchased a 430 W all-fuel, and ran the production record from Two cylinder. The tractor was originally built with underneath exhaust. The tractor now has standard up exhaust coming up through the hood.
I have located most of the original exhaust parts. Was there an original hole in the hood with a factory patch, or should I have the hole patched and re-painted? Thanks Gary
What you will be needing is part 2 #M1519T covers. 2 were used if the exhaust was stock from the factory and if it was field installed it used 1 M1519T and 1 T11970T cover back to back.
Thank you, do you know if the parts are available? if so where? According to the production record it was factory underneath exhaust.
I will print your reply so I can start looking! Thank you again- Gary
I got those numbers out of the JD 420/430 parts book. I've re-produced many of the orchard and bottom exhaust parts for these over the years, but I've not had a request to make these covers.
I don't think these would be difficult at all to re-produce even by you.
Considering I've not had a request for them, they may even be available from Deere yet
