young tractor
Hi guys Ive been getting my jd 4400 combine ready for harvest. Ive had the combine for 6 years. I apologize if this post gets long as Im hoping to describe the problem. My combine was updated at some point to have a hydraulic cylinder connected to the unloading auger. Whoever did it did a nice job. It looks like a 4420 unloading setup. I brought the unloading auger out to the unloading position just to check to make sure everything was working. When I swung it back in against the combine, the driver on the end of the grain tank unloading auger popped off and was laying right where the two separate. It looks like there is a roll pin that broke off that would hold the driver to the square shaft. I tried driving it out with a punch but couldnt get it to move. Its at a tough angle. Do you have any tricks to get it out. Its really close to a seal and bearing to heat it with a torch. Is it actually a roll pin and what size and how long is it supposed to be? My next question is how much sloop is there supposed to be between the driver and the square shaft. It seems the slop could put extra stress on the roll pin. I assume it shouldnt be a tight fit in order for the cone shape on the driver to be able to move to match up with the unloading auger. I could run the combine the way it is but with my luck the driver would fall off and never be found. I really appreciate any advice you can give. It looks like it would have been a roll pin. Ive never had this much trouble with a roll pin.
