? having trouble with belt that runs the rotor arm cleaning off trash
off screen in front of radiator not sure how it goes on any advice
thanks
study that decal inside the door carefully there is a bolt that the arm for the belt to piviot on that will freeze up and wont allow the tension to tight the belt up ...clean that bolt so it pivots freely ..I believe I had a problem with it and used a lock nut and ran it loose ... that fixed my problems .....this is for that flat belt that turns the rotary screen ...ihsmoke
