I just put a new clutch,pressure plate,pilot bearing and release bearing in my JD450 C. I've been using it for four days with no problem and it has performed flawlessly and today while pushing a little pile of sand it just stopped dead and will not move. I can shift through all the gears with no grinding with no clutch depression which tells me there is no power being transferred to the transmission. I can't see any broken oil lines from the transmission to cooler and back. Oil level is okay. The input shaft looked fine when I had it apart. I notice that the PTO is not spinning either. I am afraid it is a failure of the input shaft or something on that order.
Anybody got any ideas. I want to exhaust every possibility before I pull this engine again.
