Jd 5 mower behind a b
I have a no 5 mower being used with a jd b. When i go down the road with this mower behind in high gear. Any little bump i hit in the road makes the rear wheel on the mower go around in circles until i slow down, i am afraid im going to break off the rear wheel. What can i do to get this to stop?
Maybe figure out a way to put a spring on it to spring load it to the straight ahead position. MY 6' Deere belly mower under my JD855 has such an arrangement. By the way, I have a pair of No. 5 mounting brackets that bolt on the "H" drawbar support if somebody's interested.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">What can i do to get this to stop?[/i:654c4848f0][/b:654c4848f0]</font>"
If there is no emergency or urgent need to drive in high gear, then you might consider driving in a lower gear at a lower speed.
The No. 5 mower drawbar is designed to pivot on the tractor drawbar.
There are two designs for the No. 5 mower drawbar on mower.
Take a look at the [b:654c4848f0]DRAWBAR ON MOWER AND ATTACHING PARTS[/b:654c4848f0] diagram below commonly referred to as the "[i:654c4848f0]Quik-Tach[/i:654c4848f0]" hitch.
a251795.jpg" width="650"
Note the eyebolt (Key 5) and eyebolt tail nut (Key 6).
a251797.jpg" width="650"
You might consider loosening the eyebolt tail nut to allow less restriction at the pivot point.
Take a look at the second [b:654c4848f0]DRAWBAR ON MOWER AND ATTACHING PARTS[/b:654c4848f0] diagram below.
a251802.jpg" width="650"
Note the 3/4" nut (Key 2) and 3/4" x 2 1/2" bolt (Key 4).
a251803.jpg" width="650"
You might consider loosening the 3/4" nut to allow less restriction at the pivot point.
Hope this helps.
