My father purchased a new early 1953 "50" with the thermostatically controlled radiator shutters. That system worked great for about one year and since then the temperature gauge hasn't moved. (Gauge works). Does anyone out their have experience with the first modification to this system with the thermostat in the housing directly above the cylinders? There is no bypass as with the next modification with the thermostat near the radiator top and a bypass to the water pump. Why was this last modification made? Was there a problem with the thermostat on top of the cylinders? Thank you very much for any info!! DOA
