Having issues with my 50 generator.
It was just checked and commutor was cleaned everything tested ok, but VR was bad. I replaced the VR with a new one correct for the generator. It shows charge (+) after starting it up and for the first few minutes will continue to show charge. After about 2-3 minutes the ammeter shows a slight discharge. When I idle it down slow enough for the genny to normally quite charging, the ammeter needle will zero out. Sometimes it will go to charging for 2-3 minutes after throttle up and sometimes back to a slight discharge (-). The ammeter is hooked up properly as with the lights on it shows a discharge (-). Battery is good.
What am I missing here...or what else should I check.
Tyler in IL used to be MO
