JD 50 Two barrel carb
Help. My JD 50 has a single barrel carb. It is an early serial number. The manifold is shot. Since I have to get a new one anyway, what is involved in switching to a two barrel system? Thanks.
(quoted from post at 21:48:06 08/29/10) All you need is a different block, head and manifold and the duplex carb.
Why change the cylinder block?
That single induction 50 is uncommon and maybe worth more left original?
Manifold for a B should work.
Single induction is an early all fuel tractor only.
All gas tractors were 2 barrel.
Not sure how many were made.
(quoted from post at 13:07:21 08/30/10)
The single induction head 50 head is a late B head, and has 9 headstud holes. The 50 duplex head has 10 headstud holes, thus the need for a different block.
Yes, the B manifold should work. The late B all-fuel manifold and 50 all-fuel manifold are the same part.
But I do agree w/ you B&D, I would leave the single induction system on it.
B&D, stud pattern is alltogether different on the B and later (2 barrel) 50's. 10 studs vs. 9. have to change the block to change the stud pattern, need different head so the manifold will work, need the manifold so the 2 barrel will work.
I don't think many single induction 50's out there. I wouldn't do any more than I had to to it to make it run again.
