Working on a 5103 for a friend. It will not start. Found a few wires chewed through, fixed them, still no start. No power to the injector pump, checked the fuses found a 20 amp blown. If I disconnect he hot wire to the injector pump and turn the key on the fuse will not pop, other wise if the power is on and the wire connected to the pump, it will blow fuses. Can the valve be removed and cleaned? thanks
The issue your having is in the sensor "Near" the temp sensor, unplug it and your tractor will not blow the fuse,,you can just leave it unplugged and it will not hurt anything,, the sensor cost about $50,, I did have the part number here some where If I find it I will post it for you. It's one of these and I can't remember which one right now..
