JD 520 ignition switch
Warren23
I am rewiring a JD 520 gasoline tractor. The original wires melted due to a short curcuit of the white wire from the battery to the amp meter. The tractor was later wired with a 12volt coil and 12volts supplied from another terminal on the ignition switch to get it running. Now I am returning it to the original condition 12volt + ground and 6volt ignition with the knockdown resistor.
My problem is that the new JD switch is not labeled the same as my schematic from JD manual page 80-5-13 but it is the same as the old switch.
Schematic label ing,Bat, Flood, ND, Mag, and I am not sure of the GRD and Tail terminals.
The new switch labels are ing, Bat, FL,TL,HL,and GD. The labels and position of the terminals do not look the same between the new switch and the schematic. Where does the "Mag" (schematic only)brown wire go to on my switch. My switch doesn't have a Mag terminal and are the ND and GD position the same terminal?
