JD 520 Radiator Rebuild
InNjPa
Getting ready to rebuild the radiator in my JD 520. Not finding specifics in my I&T Manual. What is a good sealant to use on the cork gaskets and is there specific torque values for the various bolts used during reassembly? Thank you in advance!
I have always used paper gaskets and #2 Permatex. And a little less than spec for a normal bolt, try and hand tighten then check with torque wrench, like 15 ft/lb on 5/16, and 30 ft/lb on 3/8.
Upvote 0
Thank you for your advice. With all the work it took to get the radiator out and cleaned up, I just want it not to leak after it goes back together!
Upvote 0
