jd 5200 clutch
blackrr736
Well i broke it back apart. Cant find a thing wrong. Throw out bearing slides freely. Also i noticed i could turn the pto shaft, untill i got it about a half an inch from being bolted back tight. I thought it should turn when together. HELP
What symptoms are you looking for? I just finished a 5500 with a noise when you pushed the clutch pedal down. I also had PTO that would not stop. Tractors without hydraulic reverser have a bearing (JD7147 and guide R137609) on the clutch shaft that is a sealed bearing.(no transmission lube). Mine went out and spun in the housing.
Thanks for the manual but it does not help me with my problem. I had very little clutch before Now after installing new clutch assembly i have none what so ever. i am stumped as to what went wrong.
