JD 535 Baler
On 535 baler the cylinders that hold gate closed, one will creep open, I have rebuilt the cylinder twice and continues to do the same thing. Question the block that is on the baler under the cover there in the front, is it possible to have a leak or something else internally in the block cause the gate cylinder to not stay in closed position.
It you keep bumping the SCV to keep cylinder closed and you get some hay in baler and see the pressure gauge on the baler jump up, the cylinder will stay in closed position.
I've never experience tension valve internal leakage allowing tail gate to open BUT I suppose valve could be at fault. Have you tried baling with hoses disconnected from tractor after gate has been closed or reversing the way hoses are attached to tractor breakaway coupler?
