JD 555 Coulters
denny-o
Need suggestions where to get new coulter blades for JD555 2 bottom... 4 bolt pattern, 2" hub...
I"m located near Saginaw Michigan...
Ya know, a little green paint covers a lot of mystery...
So, the 2 hub pieces are the tapered plug type that fit into each other and turn on a bolt - no bearings, just grease...
One coulter is still nearly full diameter but the other two are worn down...
Interestingly, since I posted the question I accidentally bought another 80 acres and I suspect a 3 bottom plow is not going to be the tool of choice this fall... Still, I would like to get good coulters on this plow even if it sits in the shed forever... It actually plows sod quite nicely
