Well John I bit the bullet and got a VR from JD as NAPA was almost as much $ and I would have to wait 4-5 days and with a chance of plowable snow this weekend I need the tractor.
Cleaned up all the wire ends and generator case under the new VR before installing, polorized the generator prior to starting (figured it couldn't hurt). Started tractor and ampmeter showed charging then after running for a minute or so the ampmeter needle started jumping to discharge, if I turned the switch off and back on quick the needle would go back to charging (volt meter read 14.5 volts at the battery when ampmeter showed charging) also noticed some spuratic sparking inside the generator when the needle was bouncing around. This went on for +/- 5 minutes then everything seemed to stabilized and I continued to read 14.5 volts at the battery even with the lights on.
Is it possible that the eratic charging at the beginning was caused by the generator not working properly for some time or do I still have a potential probblem.
