cole in mo.
I bought a Kuhn 108 speed rake, (hay rake) instruction say to use a tractor that has float mode in the rear remotes. My 5303 does, but will my 60"s hyd work that way?
(quoted from post at 22:51:35 03/20/14) Seems to me, if the power-trol lever is left in the rearward (down) position , you have float mode. Works that way on mine. HTH
(quoted from post at 09:23:44 03/22/14) There absolutely IS SO a float. I use it on my 3 point & on my implements with a 2-way cylinder DAILY.
