JD 60 power steering plug placement
My dad and I have installed power steering on a JD 60 and would like to drill the hole in the front nose piece to access the fill resevoir ( if that is the right word). Can anyone give me some dimensions as to where the center of that hole should be? Like maybe from the seam between the hood and the nose piece to the centerline of the hole for one dimension and a measurment from the center of the nose piece to the centerline of the teh hole for the other dimenison.
Hope this makes relative sense.
Many thanks
Here you go:
1. from the seam between the hood and the nose piece to the centerline of the hole ............. 12 3/8 inches.
2. from the center of the nose piece to the centerline of the the hole .................................... 1 1/2 inches
hole size is 2 1/2 inches. The hole is on the left side as you sit in the seat. Going to be doing this myself soon.
