JD 630 6 volt Coil Testing Troubleshooting
jd6307
Hello:
I was wondering the proper testing procedure for testing a 6 volt coil for a JD 630 row crop tractor. What should the correct ohm reading be when placing on fluke ohm meter. Not getting spark to spark plugs. Points look good and new condenser was installed. New wires from distributor to coil.
Remember..now-a-days, New Condensers can be bad when ya buy them..
You can "Charge" a condenser (they are like a temporary battery), then Dis-charge them (short them) and you will see and hear the "Spark" if it is good..
A very Basic test, but will give you a good idea if it is good or not..
As long as the Coil does not test as an "Open Circuit", it should give spark..
The "Starting circuit" of the 630 throws a full 12V at the coil for starting.. are you SURE the By-Pass is working and you actually are getting Voltage when the starter is engaged..??
Hope that helps some...
Ron..
Unless switch was left on and fried the points, the coil should be at the bottom of the list of suspected parts for no spark.
Can't tell about points by looking. With switch off, the wire from coil to side of distributor should read near open circuit to ground with points open and short circuit to ground with points closed. I would first suspect that points are not making good contact.
With switch on voltage on the wire should be near battery voltage with points open and near 0 volts with points closed.
Clean points by pulling a folded dollar bill through the closed points.
6 volt coil will read close to 1.5 ohms across the + and - terminals and quite high from either of those to the high tension connection. 20,000 ohms on one nearest me right now.
With points open remove coil wire from distributor and arrange for 1/4 inch gap from the end of the wire to ground. Then use a screwdriver and short the point arms, if the coil can produce spark and the condenser is good, you will see a spark. You should also see some minor sparks at the point arms shorting point. If you have no spark remove condenser and try again - still no spark from coil but point arms do show minor sparks, the coil is likely bad.
Its more often points are the cause or at times the condenser, but the coil is my last suspect. LV primary is around 1.25 to under 2 ohms on a 6 volt coil
To find the cause of no spark run my procedure linked below.
John T
John Ts Troubleshooting
