Willow Lane
Location
Central Maine
I was unloading a forage box the other day and noticed fuel dripping off the injector pump and could not see the source. Since I was about done for the day, I finished up and parked the tractor. I went out today to try and diagnose the problem, now there is no sign of a leak. I ran it until everything was warmed up, still dry as a bone. Any suggestions other than run it and keep an eye on it. The pump only has a few hundred hours on it since it was serviced.
Thank you.
If it's still got the original fuel lines on it I'd be replacing all rubber fuel lines. The original lines had a cotton braided covering on. Those lines were notorious for causing leaks and all sorts of running issues. Even if it's not the cause of the leak I'd still replace them if they're the original lines
