JD 650 Hard to start
hawkeye38
My JD 650 lawn/garden tractor is getting up in years & has not had many maintenance problems.
But now it is getting progressively harder to start, sometimes requiring a battery recharge before it will start.
It has the Yanmar 2cyl diesel engine. The fuel heater works well as shown by a battery charger ammeter.
If it was a gasoline engine I would use starter fluid but the manual says absolutely NO!
I need suggestions on what to do to to help it easily start.
Thanks in advance.
You don't say what the age of the battery is, or if you have had it tested recently. I wonder about the battery condition when you say it sometimes needs a recharge before starting. If the battery is weak and drawn down by the preheat, before you start cranking with the starter, the engine may be turning slow enough to start hard. I would start by checking voltage across the battery terminals and at the starter at rest (before cranking the starter). Monitor the voltage at the same two points while using the preheat and again while cranking the starter. Record the changes and report back. Use care to be sure the tractor is in neutral or park while doing this testing.
(quoted from post at 09:08:55 07/20/22)
Battery is a 3 yr battery and is just over 1 yo.
I have checked the at rest voltage "preheat on" voltage and they are good. I have not checked it while starting. I will do that and post back.
How many years of warranty it has really means nothing. I have seen batteries less than a week old fail. You are on the right track by checking the voltages to see if it is holding under load (voltage drop) to eliminate an issue in that side which may affect starting. If you would please include the voltage readings you get, they are more meaningful than just saying they are good. Most like to hear the details as they help you search for answers.
(quoted from post at 10:24:51 07/20/22) My JD 650 lawn/garden tractor is getting up in years & has not had many maintenance problems.
Thanks in advance.
Fuel heater ?
Have you measured the current to each glow plug ?
Have you measured the voltage across the starter while cranking ?
This battery is an Ever Start (Walmart). But this has grown progressively worse for about 15 years but always manageable. I probably have had 5 or 6 batteries in that time span. Some were big name batteries but no better.
This morning I checked the voltage. No battery voltage is 12.8v
and drops to 12.6v when preheat is on. With preheat off, cranking voltage drops to11.6 v. Pretty good drop but tractor did start ok. Should that drop be acceptable?
I'm still wondering if there is anything else that could contribute to this problem. I'm using highway diesel. Air filter is clean. No fuel leaks. I'm kinda baffled.
I meant to say the no load voltage is 12.8v.
I have a 1981 650 myself and I have had to replace a piston in it 2 times because of ether (aka starting fluid) got used on it.The first time I got aggravated with it cranking very slow once and sprayed it as it cranked I heard it shatter the piston. My stupidity cost me ~$150.00 that time. 2 years ago I foolishly loaned it to a friend to smooth his driveway with my box blade in cold weather and instead of taking the time to use the thermo-start system he gave it shot of starting fluid, There went another piston this time just the piston w/rings was $145.00 then all the other stuff was added to it. What I thought was so stupid is he runs a garage that specializes in Ford diesel trucks.
So, yes keep the starting fluid away from these engines. The model number of that Yanmar engine has a J in the number which means almost all the main engine parts will be propritary to John Deere and expensive. They are good machines but will not tolerate any stupidity like starting fluid! If you have a good hot battery and the compression is good it will crank without the thermo-start system in 45* weather here in central Ga.
Gene Davis Tennille, Ga.
Any smoke out of the
exhaust when cranking? If
not maybe the injection
pump is getting weak.
(quoted from post at 11:58:12 07/21/22) Any smoke out of the
Seems like there is some smoke but I'll check next time.
(quoted from post at 14:16:56 07/21/22)
Well it cranked up immediately today so no smoke to see during cranking. It did smoke a little just as it started but I think that may be normal.
Have you checked the glow plugs themselves? Just because the cold start aid is energizing the glow plug bus does NOT mean the
glow plugs are good and working! They could be open and so when the cold start aid relay energizes the bus it's just like
plugging in the trouble light with the switch on but the bulb is burned out! That is, all systems are go but no light! Replacing
the glow plugs is not difficult. Much like spark plugs in a gas engine. New glow plugs have solved many tough or no starts here
in OHIO.
Hope that's helpful.
Have you inspected the battery and starter cables? Not just right at the ends, but also were they go into any sheathing.
Could you test the cables with an ohm meter? I do not know enough if that would tell you anything or not.
Also, would not hurt to polish up the battery posts and cable ends.
Just throwing things out there.
(quoted from post at 20:55:19 07/27/22) Have you inspected the battery and starter cables? Not just right at the ends, but also were they go into any sheathing.
The glow plug checks good, 2 ohms, but I think is the original. I have ordered a new one.
