JD 6620 Combine
Rich.Fl
I am trying to drain and refill the final drives on a JD 6620 combine. The manual says there is a fill, check and drain plug. I can easily find the fill and check pipe plugs, but do not see a drain plug anywhere. Anyone familiar with these? Did they all have a drain plug?
Thanks!
Tony and Muir Hill- Thanks for your input!
I attached a close up of the flat area I think you were talking about. That is a pin that is smooth on both ends. Looking at the parts diagram both this pin and the bolts are centered in a shoulder/flange where the two halves meet, so don't think removing one will allow oil to drain. I will see what I can pump out via check hole and go from there. Thanks!
Rich
