JD 6620 throttle linkage
Chris95
Ok guys. I just bought this 2100 hour 6620 and the throttle leaver is loose it will not hold in any position. How do I get the console apart to get it tight? Besides that it needs a bearing on the cylinder drive and the AC charged. It seems to be a really good machine so far. So going from a MF 300 to this, I'm pretty happy.
I think you can remove four screws in each corner of the lever box and you can get to the linkage that way. I will have to look at mine and let you know. It has been a while since I have been into the linkage.
Here is a parts break down. You may just need to tighten the nut up on the lever pivot. It has the friction washers on it.
