JD 70 6volt system
Ballast resistor. Coil voltage is closer to 5.0 volts however when running, full battery voltage while cranking.
If you run the F.I.T. coil protection circuit. A ballast resistor is not required.
1-800-522-7448 for the electrical,power steering and service manuals.
