JD 70 diesel fuel bleeding problem
TimRider
Fuel line cracked I replaced it changed fuel filters bleed system per manual won t start drug it around will fire on one cyl but won t run any ideas
Have you bleed the trapped air out of the fuel "rail" that the two injection pumps mount to, at the little screw, Key #2, that is in the head of the hollow bolt (Key #4) protruding from the upper LH side of the engine block?
<img src = "https://i.imgur.com/yJ9i1Hs.jpg">
don't know if it will work on your JD,but almost any diesel will bleed and start if you leave one injector line loose where the line fastens to the injector.
