Glen in Iowa
Seems like I fight the straight ahead or neutral position. Some tests I have done: main pump flow is 5.2 gallon per minute at 1000 psi and oil at 150 degrees. It does seem to warm up rather quick. Worm end play is .0015 in. Worm backlash is is 3/8 inch measured at steering wheel full left, full right, and center. The steering worm helix adjustment seems unclear. The book says to move actuating sleeve laterally. That means front to rear to me. Tightening or loosening the screw with 7/8 socket makes no measureable difference with a dial indicator. What have I missed? THANK YOU
