JD 70 won't start
Carter W
I inherited an old JD 70 riding mower with a Tecumseh engine model VH70. I took it out today and ten minutes into my run it died like a flash. It won't start now. It has spark and gas. It turns over but all I get is a pop, pop, pop from the carb and exhaust and when I stop trying to turn over the engine white smoke comes out of the carb and exhaust.
Is my inheritence about to cost a lot of money?
Thank you, men.
If you have fuel and spark it sounds like timing somewhere. Either something caused the frlywheel to slip and it's sparking at the wrong time or maybe a gear wore out and your valves are off time.
It could be the intake valve is sticking. How is the compression sound when you try to start it. Remove the spark plug and use your thumb as a compression tester. If no compression, remove head andsquirt some solvent on valve stem and then tap valve back down. Also clean and check sparkplug. Is it gray, black or oilie? Oil from worn piston rings can cause this partial spark (pop, pop, pop, but not thru carb. I have to clean my really old B & S, every 3 runs, as I don't want to pay the price of overhaul, when I probably can pick up a used one cheaper.
Ultradog is also right . The PO could have hit a rock real hard and sheared the flywheel key. Remove bolt or hand starter cord to view it. Use impack wrench to remove flywheel retainer nut. You should be able to tell if the aluminun key is partialy sheared. If so use a puller made out of apiece of steel with 2 holes drilled to coorespond with the 2 boltholes on the flywheel and use a bolt ar threadeded rod to put upward presure an flywheel. if if doesnt come with medium presure on the nuts, hit the downward on the metal puller. Once your get flywheel lose, take the key out, Line the keyways up and reassemble the flywheel on the tapered shaft without a key (It only help to get correct timing). use an Impact wrench on retainer nut realhard to keep it from slipping on the tapered shaft.
Do not use a gear puller on outside of flywheel, or you probably be buying a new flywheel.
All the above fixes are your time (no material) and cheap. Overhaul is very costly however. The rings may not have resealed themselve. Also use 30W oil (no detergent). If you used detergent oil 10W 30W and the PO didn't, you may have cleaned all the carbon out of the rings which will now lead to excessive oil usage, and folled sparkplugs.
I think your engine is probably without points and gets it timing thru the magnet on the flywheel. causing current to the coil directly.
Charles Krammin SW MI
Do you know that there is no water in your fuel, that it is clean and fresh, all that is in it?
The VH70 Tecumseh has a set of points and condenser under the flywheel. You will find 3 holes in the flywheel under the recoil cup. The proper way is to use a 3 bolt grip puller or flywheel knocker, but a babbit hammer will knock it loose too. There is about 1% chance the flywheel key is sheared. Aluminum keys is a Briggs & Stratton thing.
I would be more concerned with compression.
