JD 720 Hydraulics
I'd appreciate some advice please. All of a sudden the bucket on our JD 720 utlitiy tractor stopped opening and closing. It moves up and down fine. My first thought was to replace the seals in the control box beneath the seat. Then someone told me it's probably just dirty or obstructed quick connect connectors. So, I took them apart, bled and wiped them clean. Now, the bucket will barely move up and down. What's wrong and how do I fix it!? Is there air in the line and how do I bleed it? How do I know if something is obstructing the flow? How do I clean it out? Do I return to plan A and replace the seals in the control box beneath the seat? I'd appreciate some advice, please. Keep it simple, I'm not a mechanic. Thank you! Bob
Bob, did you ever get any help with your problem? I have never had that experience, but I think the thing to do would be to check the pressure at your outlets. As far as air in the lines, I have NEVER found that to be a problem. Even after replacing hoses, by cycling the cylinder a few times they would always work again.
