JD 7210 More Power
farmboat
I have a 7210 JD and need to turn the fuel up.It has a Lucas rotary pump I think I can turn the fuel up by removing one of the cap on the outside of the pump is this correct? which one?
What are you going to do with the extra heat and driveline stress?
Does the tractor use the same turbo, injection pump, injector tips, water pump, radiator, piston spray cooling the larger 7000 ten series uses?
How far are you planning on dialing her up? Does the neighbour have a 8000 ten series you need to outpull?
