jd 730 LP converter kit
I found a place in Minnesota called Carb and Turbo Systems, very nice folks, who also provided generous tech support. One thing you might find with your M4, sometimes the end (the aluminum casting which holds the M4 to the bracket on your 730) warps, just a tiny bit. Be prepared to machine it perfectly flat, since, at 200 PSI, the neoprene gasket will not always hold otherwise. Just sayin'. Good luck.
