jd 730 taper lock
kurt v
just got the tractor , was told fly wheel had a crack so allen machine taper lock flywheel was installed. The thrust was not set correctly so I have to redo it, when blocking the clutch pulley is clutch engaged or disengaged ?
thanks
kurt
Thinking about it now as long as I'm wedged against the center bolt(crankshaft) clutch end of crank engaged or not makes no difference.
